S_I_N
I want it even more than I did before![]()
Looks awesome S_I_N but i'm deducting points for the DVD drive![]()
just temporary for now will be taking it out when I get an external and making it back into a hotswap bay.
I think the front bays do look good like that. Otherwise I think that the front would be too white.![]()
I agree totally it breaks it up very well.
I didn't realise how much bigger than the HAF it was - its a monster. Lookin' Good.![]()
yeah shes big and weight wise about the same as the HAF932
now to squash NZXT's claim of 90mm of room in the top well they be close but off by 4mm the top of the non removable portion of the optical bays to the inside of the roof is 86mm just enough room for a 60mm rad and 25mm fans but the top of the opti bays is solid so about 1/3rd of the fan would be obscured. For now I have 2 fans on it in push which is plenty for my oc. I'm contemplating a 420mm rad up there and will move the fans to pull with 3 140mms above the roof under the louvered section. I also intend on a 280mm rad in the floor. This is why I'm thinking 420mm in roof XSPC doesnt make anything for 140mm fans (well not 280 or 420) So I'd have a XSPC logo on top and Phobya on bottom lol so if I make them all 140mm fan rads then I'll have matching logo's lol. Plus I need new fans as my sickle flows leds are not all the same intensity lol. As I'm getting some Bitfenix Spectre Pro fans (when they decide to send them) from the contest I won. I figured I'd get more of those and complete the look
Thank You all for the comments I'm sure lovin it so far
