Project: SR-2
That monitor looks awesome :), now that i've got a job, i'm really tempted to get one
Same here. :p
Only I'm looking for a Benq or iiyama monitor :p
Still looking at the Benq 2420t or a 27" monitor from either of the companies :p
But really that monitor looks sexy :drool:
The display is fantastic, there's no doubt about that, but the shiny plastic material used lets it down :(. You can't complain for £200 though :)
That monitor absolutely looks epic indeed. Too bad this company doesn't seem to be available in the Netherlands. Because it's really, really cheap for a resolution like that :D
Where did you buy it if I may ask. I might even get it shipped to the netherlands for that price if the shop where you bought it allows it. Or did you go for eBay?
Yeah,it does have a poundland bezel and backpanel....
I went with GreenSum on ebay.
So,im testing all the cards today,waterblocks GO!!
And this is the reason i routed my hose on my bench like i did...
If i want to test stuff,i dont need to mess around with the loop,i can just pull them out of the way.
Tidy!
Now to the good bit...blocking up the cards.
Plenty of cheescake,thanks nVidia!
Once the cheescake has gone,we can bask in the glory of a naked die.
The real reason you cant go mental with the volts on these cards....seems a power phase is missing.
Thermal tape? Yes.
Remembered to take both sides of the film off? OOOh Yes.
Watercool do a very clever washerlock system,no more scrabbling around of washers! Yay!
Sexy yes?
Watercool blocks are just too gorgeous.....everything is bang on!
Only problem i have right now is that i have damaged the port o-rings so i need to get them replaced....lucky i noticed now rather than on fill up!
One down...2 to go..
