Project: SR-2
After speaking to Ricardo from ColdZero, i managed to get this done.
a nice little sli bridge cover!!
http://www.coldzero.eu/
They do a remarkable amount of plexi modding bits and are well worth a look for one off pieces,backplates,front panels.....the list goes on!!
Rapid turnaround and great customer service,i recommend you take a look.
Look what came in the post...one short tho.
Oh so sexy.....
Nowhere near the same amount of mill marks as EK....
The plating is very good!!
The wrong way up for my purposes...
So,out come the allen keys...
.......orly?
I have a method for these tricky o-rings.
Get the o-ring in the groove at one end.
Slide the block piece over the end you just placed,after pulling the bolts out of course. You dont want to snag the o-ring and damage it.
then bolt it down...simples.
I've been away from the forums for a while and just got caught up on your build, this rig is becoming so epic... I don't think words can justify it...
Respect.
Not really build related but i gots me a new monitor!
Achieva Shimian 1440p 27" IPS.........for £200!
I have one stuck pixel on the far right of the screen but its well out of the way and is soooo tiny that it only shows on black screens.
The colour tho,is something else,very vivid....makes DayZ look awesome!!
