Buckroger
A special thanks to Mandy & DeepCool for sponsor me a nice cool fan & fan filters.
:wub: :wub: :wub: :wub:
Its a GS120 fan from deepcool with 20mm thickness allows for more space inside your case. eventho tts short of 5mm. compare to the regular fan in the market. i does produce good air flow at 61.93cfm. With a 4-pin PWM connector, GS120 is able to lower down the fan speed when the system is getting idle. That means noise level can be adjusted. Anyhow, this fan is a consider silent with 18.2~32.4dB.
The fan cable is made of PTFE(Poly Tetra Fluoro Ethylene), which withstands high temperature and heavy duty usage to ensure a long lifespan
Two pieces of rubber cable ties are attached to route the fan cable to make everything in place & looks nice too..
