I use Solidworks. It can even do fluid and therodynamic simulation which is very important when designing a case (not) I don't know if you can convert the parts to sketch up but since sldw is so expensive and extensive, I don't think so.
Internal work almost completed, just doing some strenght tests atm, Panels will be done during next week.
Also I'm working on overclocking the components fx8120 currently @ 4.9gHz using the Be Quiet! Dark Rock Pro C1 getting about 55°c so plenty of room for improvement.
5 Ghz was the max i got it too but it wasnt stable but will be trying again as soon as i get my case powdercoated and finally mod the roof for a 360mm rad
Work on this is going very slow atm, I got so much work to do around here
Anyway, I went back to the school where I'm having this made, and I was checking out their machines.
I have to start all over again on the outside :'(
Here's what I got for the front sofar, top part is a door, haven't done much work on it tbh:
btw, here's what helps me pay for the non sponsored parts:
You just buy some laptops with a broken screen/touchpad/keyboard etc. Than put them in a little box that looks half good and sell it on as a htpc.. pretty easy money
mesh goes in sides, top slides open. the front holes are usb and audio.
Terribly sorry about that, but there is not much I can do about it. The design is now finished and send off to different metal working shops, hoping for a better price. I'm having my doubts on the school because the years almost over which means it would be postponed severel months
