stevebarnes15
You weren't kidding when you said tight,must have had about 1-2mm clearance from drive bays when fitting mobo,
Cable management = Ouch
Dont mean to be a kill joy but wouldnt it have been easier to use a cm 690 ii
Nice rig but could do with a bit of cable management![]()
Just a question matey:
After spending all that money, why did you go with a generic PSU over a branded one which will protect your kit if the worst happened?
Any plans for another or a thicker radiator?
How are you finding your temps with the single rad?,Just installed a single to mine,and seems to be working quite nicely.
P.S
I have no sound at present, new drivers installed etc etc. All that comes up is the HDMI on the AMD cards. in my sound devices. So not sure what is happening with the onboard sound. I am about to have a play with the efi bios, And im hoping its something in their.
Sits at 29 wile its just ticking over. and I did an 8mil super pi calc, and it didnt realy budge at all on the temps. so I need to fined something to monitor tempta better than the asus software I think as sure it would of gone above 32 degreese
but then that would be practicalplus he developed a bond with his case. I thinks its always nice to have a bit of history with each build.![]()
