so im currently using a >>NZXT phantom 240<<
with
Intel i5 Quad Core Processor i5-4690(3.5GHz)
ASUS® Z97-E
HyperX FURY Series 8GB (2x 4GB ) DDR3 1866MHz
4GB NVIDIA GEFORCE GTX 970
120GB Samsung 850 EVO SSD
2TB WD CAVIAR GREEN WD20EZRX
CORSAIR 750W CS SERIES - Corsair H60 Hydro Cooling
BenQ XL2411 144HZ Monitor
so ive had it for about a year now and it gets in the way a little bit (i only have a small room) so i thought id do myself some case modding. im going to make a case from wood and perspex. i've already got some ideas for ventilation with using >>this<<. basically im going to make the frame from either MDF or Ply, im unsure about mdf because of how warped it can get so ill decide this when i come to build it. im also going to make it wall hangable so it will fit to the side of my monitor and also do some tapered perspex backing with LEDs, so when it is on the wall you will see the LEDs through perspex.
Measurements, sizes and materials
Case size: 23Hx14Wx12D MDF or Ply - Wood base, two sides and back. clear perspex side and top that will be removable.
Ventilation: so keeping in the theme of wood, the ventilation ill be using is normally used as radiator covers in houses. il be placing these on either sides of the case and ill be using wire/nylon or cloth mesh to act as a dust filter.
Upgrades:
>New Processor<
>Motherboard upgrade to keep with white and black theme<
x2 >>SSD<< to replace the 2TB hard drive
x1 GTX 970 for SLI
>PSU<
>>New cables<<
so keeping with a white and black theme the case will be painted, although im not sure on what colour variation to go for. The GTX 970 i currently have is white/black
and ill probably throw in some proper water cooling also, given that the temps will be far higher than what i currently get with just an i5 and x1 gpu.
I plan on drawing up a plan, or sketch to resemble what layout i want and what i hope the case will look like, i will post as i go along with any ideas or plans i make along the way. i am open to criticisms about using wood or any cool ideas revolving around my use with the ventilation idea.
Cheers
with
ASUS® Z97-E
Upgrades:
>New Processor<
x1 GTX 970 for SLI
>PSU<
>>New cables<<
Cheers
