Before I begin I would like to say, thank you for welcoming me into this forum, I looked around and I didnt see any rules posted on how to the following so if anything is out of compliance please let me know and if you could provide a link to the listed rule or whatever so I can read them and get familiar with them for this forum. Thank you...
Alright the people have spoken and what they want to see from me is a SFF (Small Form Factor) Case build themed after the ever popular and one of my
personal fav games F.E.A.R. so here it is and here it will begin.
The case in which I will be using as the foundation of this build will be the Thermaltake LANBOX Lite as all the compartments are modular which
will help reduce some of the construction time on some of the housings for the computer parts.
Once I get my hands onto this case (which should be soon its in transit) I will be able to examine it further and then start sketching out some possible themed render for the build.
UPDATE 8-20-07: Case came in today, I will get some pics up soon.
Hardware:
(The hardware I plan to run in this build)
CPU: Intel Q6600 G0 SLACR
PSU: OCZ GameXStream 1010w Power Supply // Sponsored By: OCZ Technology
Mobo: GIGABYTE GA-G33M-S2H LGA 775 Intel G33 Micro ATX Intel Motherboard
Ram: SUPER TALENT 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
GPU: On-Board Video until the 2950 comes out.
HDD: Seagate Barracuda 7200.10 ST3750640AS 750GB 7200 RPM SATA 3.0Gb/s Hard Drive // Sponsored By: Geeks.com
ODD: LITE-ON 20X DVD±R DVD Burner with LightScribe Black SATA Model LH-20A1L-06
X-Box 360 HD-DVD Player
Wifi: D-Link DWA-556 PCI Express Xtreme Wi-Fi Card (uses the PCI-E x4 slot)
Cooling:
Swiftech H20-120 Compact Water Cooling (Used to cool the dual or quad-core) // Sponsored By: Swiftech
AlphaCool Cape Bullseye Reservoir (placed in-line with the H20-120) // Sponsored By: ArcticMOD.com
Feser One - F1 - Cooling Fluid - BLACK / UV RED (custom mix) // Sponsored By: Feser-One.com
All fans used in this build was Sponsored By: AcousticPC.com
Noctua NC-U6 Dual Heatpipe Chipset Cooler (For the North Bridge) // Sponsored By: AcousticPC.com
All other hardware will be cooled with the stock cooling unless stated.
Case Lighting: All case lighting used in this build was Sponsored By: CoolerGuys.com
Hardware:
Cooling:
