This is going to be one of the bigger updates, mainly because i forgot to add some bits earlier in the log
& iv also decided to cover my desktop lifting mechanism that i filmed some months ago.
So to kick it if I will start with the hinges that had been covered in wrap, decided to cover them as
they didn't look to match the desk in plan silver, for now there carbon but this could be changed to red
as the build progresses.
your thoughts on the carbon vs red for the hinges & speakers would be appreciated, but i think its best
to wait until the internals are completed.
Im using some motobike bolts from my old Honda, made from titanium like my leg, they should help reduce the weight lol
My friends was kind enough to move my desk inside the house for me, turned out to be more easy that expected with no damage
to report or broken bones
the heaviest parts was the 2 bottom sections, but after about 30mins they was all setup in my room & fit perfect
1st things on the list to do was adding the fans, RADs, RES & some wiring
Jet Flow 120s
used some mesh & tights as the filters again, this method work so well for me over the last 5 years I cant see me changing anytime soon,
& its a good reason to have some ladys stockings in my room
Quick test of the side lighting & some fans, the light bleed on the side lights has now been corrected
Fan controler I will be using, removed the white parts & now the LEDs on the front lightup red instead of blue.
just waiting for some Phobya logos that i will stick on the front
forgot to give this a clean, but this is one of the side compartments, covered in carpet, this will hold cables, gamepags & other bits that would
normally clutter the desktop
as I said before, the hinges & speakers are getting wrapped, im still unsure what wrap i will go for,
One major part of the desk thats not been mentioned before is the lifting mechanism im planing to use.
via remote the motor will lift the glass top high enough for me to work on the inside of the desk,
but the glass can also be pushed together back if needed & rest on the speakers & top shelf nicely due to the
carefully planed angles
for the motor demo & to see the desk live please checkout the video...
https://www.youtube.com/watch?v=HxFLFPlbAgw
More updates next week hopefully
Jet Flow 120s
