In this update Iv done the final MDF primer & white primer coats on the whole of the desk,
Cut the MB tray & added a 200mm fan to the base of the desk
MDF primer
The standard PC case tray
3 big holes made in line with the fan that will be directly under the MB tray
Cut for the 200mm fan
heres the desk after the full primer, still lots to do in preparation for the paint
Heres a shot with the glass on
Should have some photos of the final finish im looking in the next update, soon as this has been done the desk will be ready to come
inside the house for the internal components & modding to continue
MDF primer
