Sup guys. I'm having a little problem planning my wc system, so I hope you guys can help me to figure this out. I want to use watercooling for my 3770k and both 670. My case is a haf x.
My plan is to buy the xspc d5 rx360 kit and, as Tom and other people I asked said, I need an extra 240mm rad. I will show you 2 pics with the plans (if you have any ideas on how to improve this, dont hesitate to comment) :
http://i.imgur.com/58Gdk.jpg <- Plan 1
http://i.imgur.com/7SehZ.jpg <- Plan 2
My question is, would the plan1 perform better than the plan 2?
My goal with the first plan is to, obviously, get the water cooled before it goes to the graphic cards, but as far as I know, the temperatures won't differ much from the moment the water enters the cpu and leaves the 2nd graphic card, since the pump flow rate is high, so the plan2 would be equally as good.
Also, if for any reason I cant fit a 240mm rad in the front (I will remove those hdd supports), would a 200mm rad be able to do the job?
thank you very much,
r3uz0r
r3uz0r
