imersa
Acrylic tubing time
More delays.. nothing unusual here. This time we lost three-phase power for 6 days. Really messing up work and any chance of project updates.
But that said... now we have something to show you. Exciting tubing at that!
First we want to quickly show you something we are pretty happy with. It was done for a friend (our very own TTL) so won't be used in this build but a nice little piece. Spec was from a pencil drawing. Single piece construction using heat to bend and designed to hold 4 SSDs:
mmmmmm SSD p0rn....!
Onto MAGNUS!
First up we remove the mosfet block from the board:
Replacing with an awesome little XSPC block:
One thing that did lose out on was due to the reverse(upsidedown) layout.. the little badge cannot be used. Not really a big deal as the build is very monotone but still wanted to do a little something....
Removed the orginal red detailing from the Asus heatsinc:
ANd in place on the XSPC waterblock:
Next up we made a small jig from a bunch of acrylic layers. It's purpose was to add the extra 30mm of space that will be taken up in the bottom of the case so I could start to plan the loop. As with all of our builds we are forever stuck in a 'catch-22'; one thing is always stopping us do the next so this was the only way to move forward:
Putting the jig to use:
Then use the jig to mark the bottom panel. Again all will because much clearer in future updates:
And more:
Next up... well... THANK YOU ASUS! We have more GPUs!
Sitting pretty with stock coolers for now:
Unfortunatly for now we are having problems sorting suitable waterblocks. However knowing they will be XSPC in style the way to move forward was to grab one of Shaun's 780's already with XSPC block:
So for anyone who hasn't worked with acrylic.. we cut ours just using a basic coping saw in a vice. Simply paired with any fittings suitable for this tubing. Bitspower and EK do these. Also spotted some other fitting systems being used but don't like the looks of these. We also hate any bending of hard line tubing. After all.. floppy tubing does the bends. If you are trying to make a super tight bend without kinking it... that's great... BUT we think there is always a better option. Thats our advise anyway. Acrylic U bends are something that make the eyes bleed.
MOAR TUBES:
That is it for today friends and fans
With this progress it really means we can get going on the build so expect more frequent updates ASAP! NOOB stop moaning now! ;D
Sponsors/Support:
Onto MAGNUS!
And more:
MOAR TUBES:
