Opinions ideas logo Redline @ OC3D !
Ok i'll have a play with it later
I finished it at like 2:30am, I really did think it was 99860 lol
All the radiuses being different are the reason it didnt look right to me :/
Yea i agree, i was rushing it.. i should be ashamed on myself
So you don't mind me goin on with the Speedometer theme ?
I scaled the OC3D logo down and changed the speedo stuff in the same color,
all the text will come (PROTO) just wanted to know if i can go further on this psd..
EDIted img..
Let me know...
Hey i like what you did with the Team number
I added some text to it, most of the time adding more pics makes it look worse so i try to keep it kinda clean...
Hmm maybe i should add PPD numbers or something ?
EDITed IMG..
Looking good, I would change the opacity on that top white circle down a little bit more, maybe change it to overlay, just doesn't look right there atm.
I also think perhaps have redline at the top curver around the bezel, and overclock3d on the bottom bezel also make the needle in red so it stands out
EDITed IMG..
Garph i am already a hour on the phone debating about a phone bill i didn't make
But that's my problem
Needs more Red. Make the notches on the dial red. Font size for redline needs to be all the same larger fontsize at the top. Loose Overclock3d from the bottom.
What do you mean by "Font size for redline needs to be all the same" as it is the same
the "arc" makes it look different , maybe another font ?
EDITed IMG..
Loving it Mr Ray. Do you reckon you could try with Redline raised out of them rim, not on top of it? I forget the name of the effect not embossed, the other one. lol
And maybe Red'ish for Redline?
And maybe only the last 4 segments of the speedo should bed Red, as we're over the Redline?
its a mix of upper and lower case i think is whats meant, can you set it so all are the same?
it looks great btw
maybe a little too much red imo but still great.
I think you mean "bevel" (see pic) ,
EDITed IMG..
I think it is "almost" there , it looks brilliant , would it be possible to have exactly the same image but with the the outer section from where the redlines start shaded slightly red as well. Then paste both images alongside each other for comment.
