SkinToxicated
didnt need the heating on in my room yesterday evening. a 920@4Gz, Gtx570 and a GTX275 all reving their their hearts out
EDIT: Oh, and get a PASSKEY and add it to the Tracker. Then enable Advmethods on the SMP/CPU Client for the first 10 work units. Once they've completed successfully and on time, disable Advmethods and enabled BigAdv instead.![]()
Kup a small question, maybe you know something I don't..
but why would he select the -advmethods flag?
I always thought the -advmethods flag added the bonus points based WU to the SMP client, whilst the internal configuration setting 'advmethods' allows beta/untested WU?
-verbosity 9, what does that do?
You will automatically star getting them and instead of 500 odd points per WU you will start getting a few thousand points per WU![]()
its showing as 11 WU, 10 completed successfully and 1 failed. I think it will happen when i get the next one done
Just a reminder.....you must also maintain a 80% successful return ratio to qualify for/maintain bonus point status![]()
^^^^Any ideas any?
