New Power Supply needed, 500-600w, £45-£55, Help please
None of above, go with the xfx 550w it is basically seasonic unit.
I wouldn't buy corsairs cx series (v2 specifically).Bad capacitors. Edit: It's not bad unit, but there are better ones in that range.
If corsair, then at least HX series.
AX is better though.
No offence but your wrong, I know for a fact that Corsair are far better than xfx.
Thanks for the help anyway.
Oh and I am wanting to buy a HX750 from someone but I just don't have £60 at the moment, the max I can spend is £50
None taken :)
Just the CX v2 series. Wouldn't go with gs series either.
They are not far better if they are both made by seasonic.
Same guts, differend logo.
CX, TX and HX series are made by CWT.
Some exceptions with TX and HX series, which are made by seasonic.
AX by seasonic.
Edit: 2 AX models made by flextronics.
All XFX psu's made by seasonic.
Again not saying that cwt is bad, just pointing that seasonic is a bit better.
None taken :)
AX by seasonic.
Fair enough but with corsair you get a great warranty and customer service and very good reliability
