New Headset (under £30 for stereo or under £60 for 5.1 surround sound)
Nathlm
Requirements:
  • Has to be have good quality audio and microphone
  • Has to be from CCL
  • Under £30 if it's stereo
  • Or under £60 if it's 5.1
Thanks in advance
I don't want to come across as rude but you will not find any good sounding speakers for that price. They are pretty much all made of cheap plastic and cardboard.
Thats also another thing. They will break. If you want good quality that will sound 10x better than the plantronics, and better build for longer lasting performance you will need to bump up to at least 100. It will pay itself off in the long run. If you are planning on purchasing another cheap set you are already in it over 100 so if you would have purchased nicer ones then you may still have alive today.
How about I throw some headsets at you that I kinda like:
http://www.cclonline.com/product/36...y-Professional-Series-Gaming-Headset/SPK1065/
http://www.cclonline.com/product/43...VO-5-1-Surround-Sound-Gaming-Headset/SPK1264/
http://www.cclonline.com/product/36...4H-Audio-Compact-Lightweight-Headset/SPK3335/
Maybe these aswell:
http://www.cclonline.com/product/65...-noise-cancelling-Pro-Gaming-Headset/SPK1315/
Kinda highered my price range a bit but oh well
The Vulcan is the nicest of them all. It offers better sound quality than the other 3. And the second i would choose is the SteelSeries, but again, you get cheap headphones they will not last long. Gaming is really hard on any kind of sound equipment.
It's only the microphone that's gone on mine I'm very happy with them. They've lasted through hell - stepped on them 5 times, sat on them ~ 3 times and pulled them too wide so they nearly crack countless times I would say they are pretty solid build quality and very good audio (wimpy mic though).
That's why I was looking cheap!!!
(Plus only onboard sound from a foxconn P55 inferno katana)
lasted ~ 9 months!
