mounting a quad rad in a tj07
ruthless_villain
hi guys i managed to get a tj07 cheap of ebay and im using it for my next rig instead of the 650D i have but i cant figure out how to get a 480mm rad in there, ive seen people put it in with velcro but im not sure how they do it, so i wondered if i could use double sided tape or L brackets somehow
they are the only three ways i have seen but has anyone ever done/seen it done differently?
i actually only just finished using the xspc 120 rad stands to mount a 120.4 & 120.2 in the bottom of my tj07.
i tried strong double sided tape but it was all a bit "how-ya-going" if i moved the case too much.
if you use a rad stand just check the bolt size as the tj07 is pretty thick.
