Mount and unmount mach II gt without taking MB out??
jirii
Hi all, I have one question is there any way have can I modde my case that Iĺl be able to Mount and unmount mach II gt without taking MB out?? If yes post some pictures and so on , I think a lot of people woul like this things because it seva a lot of time.
Thanks for reply;)
You can if you cut a hole out the plate that holds the motherboard in place i did it with mine.
As it carn't be seen with the mobo in it don't really matter.
YEs I thought about some think like you have yozu some photo and whit what instrument you cut a hole, I am not good in hand made .-DD
do not use a angel grinder! use a dremmel with cutting disc.
Oh come on, mav has a point a lightsaber would work a treat lol. Slice thru like butter!! :D
When I did mine I went through about 10 dremmel cutting disks, when I do it again (and I will be) I may use an angle grinder as suggested by the nutter that is K404 :D
