Mayhems Aurora Coolant - Pre-mixed Liquids
Test Results
Aurora
RRP £15.00
ETA **/11/20011
Not to be used with impingement water cooling blocks. Only to be used with fast flow blocks. This is a wide effect liquid using much larger particles than Aurora +.
EK WB
Supreme LT AMD Acetal AMR3 - PASS
Supreme HF (restriction plate removed) - PASS
Supreme HF (restriction plate installed) - FAIL
XSPC
RASA water block - PASS
RS240 - PASS
X20 750 Pump & Reservoir combo - FAIL
Single Slot Pump & Reservoir combo - FAIL
Laing DDC 200ml Reservoir Pump Top : Plexi - PASS
Single 5.25″ Bay Reservoir - PASS -=Out standing effect's=-
Duel 5.25″ Bay Reservoir - PASS -=Out standing effect's=-
Watercooling
Heat Killer (With Restriction Plate) - FAIL
Heat Killer (Without Restriction Plate) - PASS
Phobya
DC12-400 12 Volt Pump - PASS
DC12-800 12 Volt Pump - PASS very hight flow rate - looks like liquid is on acid .....
Balancer 150 Black Nickel - PASS -=Out standing effect's=-
S.1366 / 1156 Water Block - PASS
G-Changer 240 - PASS
Swiftech
Apogee XTL (will not be testing)
Apogee XT Extreme (will not be testing)
Koolance
Koolance CPU-370 (with small restriction plate) FAIL
Koolance CPU-370 (restriction plate removed.) PASS
Laing
DDC 10 watt (working) ( better using the 18watt though)
DDC 18 Watt PASS
D5 PASS
Aurora +
RRP £17.00
ETA **/11/2011
Aurora + Has a much smaller particle size. Works really well with 1/2" tubing showing excellent effects..
EK WB
Supreme LT AMD Acetal AMR3 PASS
Supreme HF (restriction plate removed) PASS
Supreme HF (restriction plate installed) : PASS
XSPC
RASA water block PASS
RS240 PASS
X20 750 Pump & Reservoir combo FAIL
Single Slot Pump & Reservoir combo FAIL
Laing DDC 200ml Reservoir Pump Top : PASS
Single 5.25″ Bay Reservoir PASS
Duel 5.25″ Bay Reservoir PASS
Watercooling
Heat Killer (With Restriction Plate) PASS
Heat Killer (Without Restriction Plate) PASS
Phobya
DC12-400 12 Volt Pump PASS
DC12-800 12 Volt Pump PASS
Balancer 150 Black Nickel PASS
S.1366 / 1156 Water Block PASS
G-Changer 240 PASS
Swiftech
Koolance
Koolance CPU-370 (with out restriction plate) PASS
Koolance CPU-370 (with restriction plate) PASS
Laing
DDC 10 watt PASS
DDC 18 Watt PASS
D5 PASS
Confirmation from testers :
+ 2 to 3c above water (tester 1 & 2) PASS
Non blocking when using correct mix with correct block (tester 1 & 2) PASS
None conductive upto 1 month--- only ive tested this out.
Testing complete
Next stage is refinement.
ETA
Announced
cool well looks like I'll need a new pump and res before going this route. But no hurries mate. Just got my loop running with some EC6 as you recommended awaiting dyes
cant wait to see temps now lol should be alot better But keep it up bro it still drops my jaw everytime I see it.
I'll be ordering an XSPC Rasa kit (RX360 / RX240) for my Christmas overhaul. I'll need to replace the X20 pump / res, right? Will the XSPC dual bay res (dual DDC version) and a DDC pump. Do you know if you can use the XSPC DDC pump top? I don't see a reason why not, but I'd like to make sure (coolant compatible too). I'd rather make a fool of myself here, than to waste my money and still make a fool of myself.
ywh the rasa Kit Combo "pump / Bay res" has problems with this liquid. I has tested this quite a few times. I really wish it didn't and so much wanted it to work but unfortunately that is the case.
I see no reason why as duel pump res wont work as long as the pump is not submersed in the liquid directly.
Thanks for publishing the results of your testing Mayhem. I imagine it will bias my choice of water cooling components for my new build somewhat
Cheers,
Scoob.
tbh the reason for publishing testing is to show that nearly every thing works except for the odd components. I have used a wide variety of components from popular makers to do the list so i think we've done really well.
Alright mate,
I know you don't want requests for every type of block out there but on your best guess would something like the standard XSPC Delta V3 be alright?
Not sure how restrictive it is in the grand scheme of things.
Yeah, I'm really impressed the amount of stuff this works with - job well done I'd say
Cheers,
Scoob.
Weve have created 2 versions of Aurora.
Aurora + - For CPU with restrictive blocks
Aurora - For none restrictive blocks
Aurora + is slightly more expensive due to the pearl size (this cannot be avoided)
Video of Both Aurora + and Aurora being uploaded now in my main rig ....
it looks marvelous. also if ya think about it. its like it is its own flow indicator. flip that was a lot of its. i asked he uv question earlier. say one buys this wonder liquid and adds your uv dye to it. so if you are using the computer in the day time you have natural light to see the magnificent pearly liquid but at night you turn on the uv so everyone knows ur a BA. would adding the uv dye effect the look of the aurora. or if you bought the plain white aurora and added the dye to taste if ya catch my drift
Now THAT'S what I'm takling about...two loops, two colours 'king awesome!
Will be getting me some of that for my new build...though I've now answered my own question of going one loop or two lol.
As a bonus that video also satisfied my foot fetish...
Cheers,
Scoob.
* This statement is untrue...need more foot time in that vid! **
** This one really is untrue.
Will it be available in Canada? I may have to message someone who sells WC parts. (DazMode, and probably Linus from NCIX)
If you pay for Mayhem's flights and a week or twos accomodation I expect he'd be happy to hand deliver some for you
Scoob.
* Sorry
Dude I'm sooooooooo impressed with how much progress you've made in what seems like no time at all!
These liquids are looking the dog's danglies, I just can't say enough about them!
LOL ... ERM unbeknown to most these liquids have taken over 2 years to develop and get working fully. Ill point to this very devious picture post i did back in 2009 http://www.xtremesystems.org/forums...made-UV-dyes&p=3960493&viewfull=1#post3960493
so even though its only been showing for the last few months the picure was shown way back then
check post 107 i even said what it was pmsl ....
Had no idea it'd been in development for so long, bet you're glad it's getting near to market now eh?
Reckon this stuff will sell rather well!
Scoob.
