Mayhems Aurora Coolant - Pre-mixed Liquids
Hi,
Only just checked out this thread, gotta say I'm loving that stuff. Looks good and you can really see the loop in action too, useful for a noob like me to ensure all is working as it should.
Up next: Flavoured coolant to bring the fun back to draining that loop...
Scoob.
looking good. Hopefully you have this stuff fully tested and market ready by the time I get my next build going. It probably will not be until the 2011 socket comes out, so you have some time. If it's not ready by then.... well
I'll ninja some
Hi Scoob. I have to say these liquids are not new user friendly. Were working on a different variation of this liquid that will be. The reason why i say this is because this first version were are creating is a high maintenance liquid for looks only and can only be used for a short period of time.
The second versions we are looking at producing with smaller size pearl and will work much better and be used for longer periods. How ever because of th small pearl will not looks as sparkly and will be much smoother.
mick
Your dyes look pretty sick, mayhem. I can't choose between blue and green for my upcoming watercooled build (Alien themed, and will be folding 24/7). I'll be using blue or green Cooler Master SickleFlows and either blue or green coolant. I can't decide which though.
Dead easy buy blue + UV yellow / Green. then if you what UV Green mix Blue + UV Yellow / Green at a 4:1 ratio and you will have UV green
mick
Fair enough, I'm aware they're still a WIP but thanks for confirming that. Possibly once I'm working on my new build (likely next year now) you'll be production ready with this stuff. It does look good though I imagine even with the final version more frequent fluid changes and system flushes would be recommended?
My build is a little way off yet, but I'll certainly be checking this stuff out nearer the time. Best of luck perfecting it.
Cheers,
Scoob.
Just built another rig and now testing the ultra pearl - 20 to 60nm its looks erm ... hahahahaha
well it looks like pearl bubble bath ......... its a bit ... hmm cannot say it else some might complain ... pmsl
Ill take some pictures later on ... once i stop laughing
Sounds like it'll sell if it's that entertaining
Scoob.
Pearl bubble bath? That looks like a good reason to get a case window. Staring at the inside your PC will sound less retarded now.
Edit: couldn't decide what combination of fans + coolant to use (green fans + blue coolant , green fans + green coolant, etc). I know that the new coolant isn't user friendly, but I can wait/ use your other coolant. Good luck perfecting your new coolant
does it look like something starting with the leter C?
From seeing Tom's vid from I43 I'm loving the look of the pastal blue. Any idea when it might be ready for the masses mate?
Sorry we don't have ETA. Tom has got the only sample in the world for that particular coolant.
That particular bottle is ST-Blue
Mick
Mick
I guess some longer-term testing is needed to see how this stuff behaves in a loop over time, after all this is new ground you're breaking here. It does look damn good though.
Scoob.
Just let me get some of the pearl,please,..................
free beta tester waiting,I just want that lush stuff.
Mick
Well I'll be ordering a few bottles of it once it's available Mick.
On a serious note, keep up the cracking work fella, I'm sure you'll be set to make a mint with your new lines of coolant, you really are onto something with the Pastal's and Pearls
