Mayhems Aurora Coolant - Pre-mixed Liquids
In talks tomorrow ... may have some news in next few days about possible ETA.
All so got some other meetings to attend as well ref other things.
Can you patent this? I think if this gets popular enough you could make ALOT of money
how would these work with a uv additive. would the liquid glow but the solids still stay non glowy to still get the pearl effect. oh gosh. this thread reminds me of a song by the lonely island and the first lyrics are
lock eyes from across the room
UV doesn't work well.
You get UV but you don't get the swirls as the pearl is light reactive not UV active.
BEING UPDATED
Test Results
Aurora
RRP £15.00
ETA **/**/2011
Not to be used with impingement water cooling blocks. Only to be used with fast flow blocks. This is a wide effect liquid using much larger particles than Aurora +.
EK WB
Supreme LT AMD Acetal AMR3 - PASS
Supreme HF (restriction plate removed) - PASS
Supreme HF (restriction plate installed) - FAIL
XSPC
RASA water block - PASS
RS240 - PASS
X20 750 Pump & Reservoir combo - FAIL
Single Slot Pump & Reservoir combo - FAIL
Laing DDC 200ml Reservoir Pump Top : Plexi - PASS
Single 5.25″ Bay Reservoir - PASS -=Out standing effect's=-
Duel 5.25″ Bay Reservoir - PASS -=Out standing effect's=-
Watercooling
Heat Killer (With Restriction Plate) - FAIL
Heat Killer (Without Restriction Plate) - PASS
Phobya
DC12-400 12 Volt Pump - PASS
DC12-800 12 Volt Pump - PASS very hight flow rate - looks like liquid is on acid .....
Balancer 150 Black Nickel - PASS -=Out standing effect's=-
S.1366 / 1156 Water Block - PASS
G-Changer 240 - PASS
Swiftech
Apogee XTL (will not be testing)
Apogee XT Extreme (will not be testing)
Koolance
Koolance CPU-370 (with small restriction plate) FAIL
Koolance CPU-370 (restriction plate removed.) PASS
Laing
DDC 10 watt (working) ( better using the 18watt though)
DDC 18 Watt (working)
D5 (not tested)
Aurora +
RRP £17.00
ETA **/**/2011
Aurora + Has a much smaller particle size. Works really well with 1/2" tubing showing excellent effects..
EK WB
Supreme HF (restriction plate installed) : PASS
XSPC
RASA water block
RS240
X20 750 Pump & Reservoir combo FAIL
Single Slot Pump & Reservoir combo FAIL
Laing DDC 200ml Reservoir Pump Top : PASS
Single 5.25″ Bay Reservoir PASS
Duel 5.25″ Bay Reservoir PASS
Watercooling
Heat Killer (Without Restriction Plate)PASS
Phobya
DC12-400 12 Volt Pump PASS
DC12-800 12 Volt Pump PASS
Balancer 150 Black Nickel PASS
S.1366 / 1156 Water Block PASS
G-Changer 240
Swiftech
Koolance
Koolance CPU-370 (with out restriction plate)
Koolance CPU-370 (with restriction plate) PASS
Laing
DDC 10 watt PASS
DDC 18 Watt PASS
D5
Update 2
Aurora base colours
Usage : For none Impingement water cooling blocks, Do not use with inbuilt low pressure pumps that are inside reservoirs.
Clear / Blue
Clear / Red
Clear / Silver
Clear / Gold
Aurora + base colours
Usage : For Impingement water cooling blocks, Do not use with inbuilt low pressure pumps that are inside reservoirs.
Clear / Blue
Clear / Red
Clear / Silver
Clear / Gold
Below Blue / Silver
Above Gold / Red
Thanks for the comprehensive guide there man. Guess I'd better read it carefully and see what I'll be needing to run this.
Out of interest in that last photo are they both Aurora+?
Loving your work as always.
Spent more money yesterday, got 2 reservoirs coming , more tubing , more fittings, more clamps ect ect.
XSPC (paul) has been very helpful with discount and so has www.specialtech.co.uk. With out these guys and all the other companies helping out with products and discounts we would have got this far this quick.
PMSL
oky this was by request from a very large (CPU) manufacturer. I have just mixed M3 Novac with our pearl for a pearl fully none conductive fluid ....
PMSL photo's will be up later on (or a vid)
AAAAAHHHH!!!!1!
Can't wait. Will you have distributors in the US? and if so who? If not, I'll order it from somewhere that will ship it to me.
I'm thinkin something blue.
The blue looks so incredibly awesome. What colour would you recommend for an alien / "Rust In Peace" themed rig?
I can't seem to get images too work. I was going to post Megadeth's "Rust In Peace" album cover.
On another note weve been asked via a second party for intel if our pearl will work on 3M products. So tonight i set about testing it and found it does.
Longer term testing is needed how ever on the NOVAC 649 with has less mass than water and less viscosity than water .. well ill let the picture do the talking ...
we dont have a spare loop at the moment for this to test on but will do at a later date.
im hoping to get some more updated liquids from 3m Soon for further testing as well.
