Major game running problem
chownsy
afternoon ppl,
im not a noob but this has gone past my capabilities,
i have been in contact with specialtech too bout this problem
i could neva run games on my system cause i had got no good ram
i was running ddr256 or summat that low, i now have upgraded my ram to
ocz platinum ddr400 with low latency timings. i have updated my amd
running with the patch and installed all the latest graphics drivers.
when i load a game from first thing of turning my computert on and letting it settle down the game will run fine til bout 5 - 10 mins into the game where it
will start to lagg and freeze up, it will free its self after a few seconds but then freezes again, i have tried 2 and 4 gb of ram but still the same. if i leave computer on for 10 mins then try th game it wont get past the credit page of battlefiel 2142. i have tried counter strike source too which laggs too.
its not my connection at fault. my system is as follows:
ASUS A8R32-MVP DELUXE
MAXTOR 400GB SATA HARDDRIVE
4 GB OCZ PLATINUM PC3200 DDR 400
WATERCOOLED CPU AND NORTHBRIDGE
ATI RADEON X1900XT GRAPHICS
AMD ATHLON X2 939 SKT TOLEDO 4400+
2 x DVDRW DRIVE
please can someone shed some light on this silly problem
1 thing i can say is my harddrive is very noisy when accessing data
sounds like a subwoofer wen in room below it
add me to msn if you want to guide me through any think you have to suggest on : rchowns9@hotmail.com
cheers
richard chowns
settings
how do you mean setting, im running it at 2.7v which im safe to 2.8v
i have left everythink else virtually standard
no i havent, this is a new rig, been running 2 months with the old ram.
i put 4 gb of ram into it today but tried 2 gb only too
What speed and multi is your CPU running? What is your HTT set to and What timings / speed and command rate is your memory on? (eg 3-3-3-7, 220mhz, 1T)
These may be labeled differently though. If you run some stability tests like super PI 32m or prime95 you might be able to rule out any bios settings being off target
bios settings as follows if this means anythinky to you
VCORE : 1.392V
FSB MULTIPLIER 11X
HT LINK : AUTO
CPU: RD580-NB HT LINK WIDTH 16BIT
FID/VID CHANGE:
PROCESSOR FREQUENCY MULTIPLIER : X4
PROCESSOR VOLTAGE: 1.400V
DDR VOLTAGE:2.70V
PCI LATENCY TIMER : 64
MEMORY CLK 200MHz
CAS LATENCY :2.5
RAS/CAS DELAY 3CLK
MIN ACTIVE RAS 5CLK
ROV PRECHARGE TIME: 2CLK
RAS/RAS DELAY 2CLK
ROW CYCLE: 11CLK
ROW REFRESH CYCLE: 14CLK
READ WRITE DELAY: 4CLK
READ PREAMBLE: 5.5ns
ASYNCHRONOUS LATENCY: 7ns
CHEERS
richard chowns
i tried call of duty 2 and it runs fine on single player
play half life 2 and on the menu it freezes up alot,
same with batlefield 2142
well i got loads of games but none that are demanding but single player
is there summat i can do to test whether its to do with net
im using a router and on board lan settings
when i was coping a dvd my computer was really slow.
my windows media player would not load and the computer really slowed
down
down
Are you implying that hes copying a dvd every time hes playing a game without his knowledge? lol:)
name='Dav0s' said:
And when i was running my 2 x 512 ddr256 and ddr400 ram it would neva freeze.
the compatabilities with the new ram and motherboard are correct from all the specs i have.
could it be something to do with t1 and t2 people keep saying to me but i cant find where i find it in my bios, Llwyd you got the same motherboard as me, do you know where it is located.
thank you
Hmm deffo need to change the timing to 2T in the BIOS. I think it might be called something like "CPC". I think if this is disabled then this sets it to 2T (CPC = Clock per Clock)
thought it would be down to that because my last ram was not dual channel and this is with extended latency too.
so you say if it says disabled its 1t or 2t so i get it right lol.
:worship: if its correct and u fix my problem :worship: :worship: :worship:
i have changed my 1t to 2t and to no avail,
it still freezes in game, i have run 2 stress tests, 1 was the 3dmark05 and
my score is 10655
How do u do a test-mod runthrough type thing in bf ? I have no interest in the game myself, but I seem to remember from .... pfffffft..... 10 years ago or more that the likes of Unreal and Halflife used to let u benchmark/test em from a console.
Can he - or is he able - to try that ?
