pcjunkie429
Just a quick note: According to Martin's Liquid Lab, the XT45 will perform slightly better at low fan
speeds than a UT60, and for most of the rpm spectrum is pretty close to it.
Just FYI.
Just FYI.
That's...interesting.
Looking at the stats on martin's liquid lab suggests it isn't really a worthwhile upgrade. The difference between the RS and RX at 1000rpm (my chosen fan speed) is only 10W and my EX model is somewhere between these two. I don't think an extra 10W of heat dissipation is really going to be worth the £50 or so that the radiator will cost along with the time/effort needed to drain and refill/bleed the system.
Also got a good picture of how the coolant looks when well lit with the system is off. Almost colourless, it's really amazing how it takes on such a vivid green colour when illuminated with the XSPC blue LED.
Got carried away with the camera and took an arty shot of the GPU block. I liked it so much, it's become my new wallpaper.
Thanks, unique was the intention. I agree with you on the psu accents but don't think there's any easy way to change their colour evenly and keep it looking good. (Considered translucent paint or permanent ink) I'm not sure when I'll be sorting a new psu out, so the tx may be in there for a while.I must admit that I didn't like this build at all in the beginning but you've really made a pretty looking computer out of it
It's quite the unique colour scheme, which I really like. Only thing I'd say is fix those yellow accents on the PSU (but that might just be me being picky :lol![]()
Out of interest, what did you dislike before? (Happy with constructive criticism off anyone btw)
Indeed :lol:Wow, that cable management. :lol:
	...a suitable fan. (probably another gentle typhoon)
