alpenwasser
Coming together rather nicely, I must say
No please don't keep that orange fan, too many colours makes it look old and tacky imo.
Cheers guys. I agree on the amber fan, was a tongue in cheek comment.![]()
After reading it back I realise nowI was so horrified when I first saw it that when I noticed the word 'keep' next to 'amber fan' I had to say something :lol:
On a side note (lol) those photos look excellent, beautifully vibrant.
4. Replace 140mm fans with ....?
5. Replace XSPC EX240 with alphacool UT60 <- not sure it'd be worth the expense though?
6. Replace XSPC D5 reservoir with a tube res and separate top
7. Replace corsair PSU with a seasonic gold or platinum
Can't say i'm all that fond of their appearance though. I'll think on it as i've got plenty of time. Been thinking of going for scythe AP-15's all round and not bothering with any 140mm fans.Bitfenix Spectre Pro 140s. 'Nuff said. Haven't experienced them in person but on video comparisons they are amazing.
The top radiator is 45mm thick and has lower FPI. The XSPC EX is 35mm thick and has very high FPI. Going for a UT60 will reduce the FPI and almost double the thickness. If it will only give me <5 degrees improvement though, I can't see it being worth the £50+ outlay.Are they both the same rads (top/bottom)? If so, I wouldn't bother with it, as the only difference in the two (XSPC vs AC) that I know of is the AC is full copper internally, which will save you a few of degrees C, if that much at all.
The bitspower kit is what i've been looking at. Still not certain how well it would fit though as space is at a premium in such a small case. (not that i really think it's all that small)But that would mean losing the magical coolant-color-changing properties of this res. :lol:
If you do, I'd go with a Bitspower black POM Mod Top, D5 mod kit, and a Bitspower D5 Upgrade Kit 150(includes a pump top-mounted 150 mL res). I know you said you wanted a separate top and res, but I've seen the above combo in other rigs and it looks the danglies.
If you must have the pump and res separate, I'd still go with the Bitspower mod top and D5 mod kit, and get either an EK or Phobya tube res. If you go with the separate tube res, get the EK Uni-holder and mount it to the 2 bottom 5.25 bays, then attach the brackets that come with the res to that, and get a UN designs Z2 bracket to mount the pump to the inner-most 120mm fan on the bottom rad (the one closest to the PSU). Then you can use a length of hose to connect the res to the top-facing port on the pump top. This route is more complicated than the latter one, but both will look good, IMO.
True, it does mean redoing some of the sleeving, but paracord is dirt cheap and my corsair psu could be considered practice. The big advantage of going modular for me is that there will be less cables to hide, meaning i can make things much tidier. (which will please seekax :lol: Not that i'd be buying a new psu just for that) Main thing for me is it'd be more efficient and i'd hope that the fan would be much quieter. (the yate loon in my corsair is the loudest component in my system)Why? Lol that would just mean having to sleeve all the necessary cables again. Why go to that trouble when you've already done it to this PSU? :headscratch:
It'll get there. It doesn't help that coolermaster didn't give as many cable tying locations on the old usb 2.0 version of the case.if you fix that cable mess on the back i will be happy
oh yea, and new fans, these look a bit cheap.
this is pretty much how to build a small sized waterloop lol
oh, couldn't see that, the ugly fan guards covered it upThanks guys.
Don't think you are going to get anything better than gentle typhoons on the radiators. I'll be changing the silver/gold fan guards out for black which should improve the look but the fans are definitely staying.
that is exactly why you would buy a new PSU, either it pleases me or in the trash with it! :lol:(which will please seekax :lol: Not that i'd be buying a new psu just for that)
