is it worth changing the fans?
remember300
Active member
I have the standard corsair case fans and standard rad fans, i was thinking of changing the rad fans to high performance static pressure fans suck and blow so thats four fans and then 3 more for the case but just high performance as they dont need to rely on the static pressure 1600rpm on those fans is enough, id rather go for performance than silent.
is it worth it ... my case is the c70
open to all opinions and im not looking for WC as i only use 1 gpu atm and have the h100i already and running
The only option i could say, if you aint thought about already is get the Corsair SP (Static Pressure) there really good, if not the best static pressure fans on the market, just do push pull if there's enough room, and temps will lower like mad!
CSheldon
i will have to mod the case which i shall be doing ad i had statics in mind for the rad and then two for sucking air through that tight bay at the front of my c70 then internal add two high performance and change the exhaust to a high performance
What i'd say is, go for a SP Push/Pull on your H100i, and then use Performance fans on exhaust, and normal intake if you so wish.
i only say static fans on the front due to the fact they are designed for tight situations and you cant get much tighter lol
Well just use high performance, for tight squeezes, you may just get that little extra more airflow, but that's up to you that.
Yeah, if you go with the 4 Static Pressure Corsair Dual Pack, as they are the best rad cooling fans around now, just use 2 from that, and see if there is a noticable difference, if you buy an High Performance for Exhaust, and then just check, and it saves buying extra fans, which will be pointless.
i do its a good idea and that double pack was what i was gonna get anyway, and until i have the time to fabricate the unit on top, and i dont want just two fans on the roof of my box i can use them in the case.
do you know about painting or dying the grommets you get in the cases, as i want to die or paint mine 1 of 3 colours depending on my financicial situation at the time
