HourofWolves
I recently decided to add two more RAM sticks to my computer setup as I was getting close to 16GB at some stages of use.
I made sure to get exactly the same set as was installed in the system when I first built it: Corsair Dominator Platinum 16GB (2x8) DDR4 3000Mhz 15-17-17-35 (CMD16GX4M2B3000C15).
I had the current sticks in DIMM_A2 and B2 respectively so put the newly purchased ones in A1 and B1. However, when I went to boot back up the computer did not load the BIOS. Thinking that maybe they weren't exactly the same I took the new sticks out to check. Everything is the same, except for the product barcode number (I assume this is just the difference in year).
I next tried taking out the old sticks and putting the new ones in slots A2 and B2 and it did not get to BIOS with this configuration either. I then put all four sticks back in in their original slots and used the Clear CMOS button on the back of the Motherboard, this worked and got me into the BIOS.
At this point I thought it might have been the overclock I was running so I set everything back to default and tried to boot again. Still nothing.
Looking at the Q-Code I am getting on the motherboard it is reading Eb which is "S3 OS Wake Error".
With all the sticks in I have been able to get it to BIOS about 3 times, and have managed to get it to Desktop once though I didn't do anything differently. When I did get to Desktop I entered BIOS on startup, exited without changing any settings from default, it then BSODed and then booted into Desktop. Every other time gets me the Q-Code Eb. Taking the new sticks out gets me to Desktop without any trouble.
I have tried:
I have found both of these threads which seemed to have had similar issues but different enough that I thought I should start a new thread:
https://forums.tomshardware.com/threads/installing-exact-same-ram-but-system-not-booting.3454551/
https://forum.overclock3d.net/showthread.php?t=91297
In one of those threads a BIOS flash worked, however I already had the latest BIOS installed before getting the new RAM. Do you think if I flashed the BIOS again with the new sticks in it might solve the issue?
Or considering the error is to do with "S3 OS Wake Error" that a clean OS install might help?
I have also read that the memory controller on the first generation Ryzen was a bit finicky, would upgrading to the 3xxx series solve my issue?
Any help would be greatly appreciated.
PC Specs:
2x8Gbs Corsair Dominator Platinum DDR4 3000Mhz (purchased 2017)
2x8Gbs Corsair Dominator Platinum DDR4 3000Mhz (purchased 2020)
AMD Ryzen 7 1700 (NZXT Kraken X62 cooling)
ASUS Crosshair VI Hero
ASUS Strix GTX1060
Samsung 960 EVO (OS drive)
WD Black 1TB
Corsair RM650x PSU
Windows 10
OC Settings:
BCLK: 100
CPU Core Ratio: 38
Mem Freq.: DDR4-3000Mhz
Dram timings: 15-17-17-35
Gear Down mode: Disabled
VTTDDR Voltage: 0.70620
CPU Core Voltage: 1.35
CPU SOC Voltage: 1.05
DRAM Voltage: 1.35
Thanks in advance.
I have tried:
- Clearing CMOS
- Turning off PSU and unplugging
- Moving RAM around DIMM slots
- removing OC
- setting RAM timings and speed in BIOS without CPU OC
PC Specs:
ASUS Strix GTX1060
WD Black 1TB
Corsair RM650x PSU
Windows 10
OC Settings:
BCLK: 100
CPU Core Ratio: 38
DRAM Voltage: 1.35
Thanks in advance.
