In need of a little bit of help
cbiltsouris
hey everyone
I purchased 3/8 ID and 1/2 OD enzotech nickel plated compression fittings for my build, however I also purchased 3/8 and 1/2 primochill tubing and for some reason they dont fit!
unless im putting them on the wrong way or somthing?
Normally it would be 1/2 inch id tubing for 1/2 od fittings
if you're using compression fittings it will have to be the right tubing
for the 1/2 od compression fitting you should have 1/2 id 3/4 od tubing
If your tubing don't fit, there's something wrong somewhere
If the tube is 3/8"ID and 1/2" OD... And the compression fittings are 3/8" ID and 1/2" OD it should work, can you not get the compression ring over the tube?
can you measure the outside diameter of the tube. maybe they sent you the wrong stuff. Measure the compression ring as well. not the barb, but the removable ring.
