well going both hardware would make the performance lower since it would be cooling with warm liquid instead of liquid cooled in theory
A common misconception.
Check out the first table on
this site, specifically, the water in and water out temperatures.
You'll see that the temperature difference between the radiator's inlet and outlet is somewhere
between 0.71 °C and 0.2 °C. Now, considering that a radiator dissipates the heat of all
the components combined, it stands to reason the the temperature increase over each
component must be smaller than the combined temperature drop over the radiator
(example: Say you have a 130 W CPU and a 250 W GPU in your look with one radiator; that
radiator will need to dissipate roughly 380 W of heat and have a certain temperature drop
over its in- and outlet, and that temperature drop will always be larger than the temperature
increases over the CPU and GPU block, respectively).
Bottom line: It does not matter if you have a radiator between each component or just all
the radiators in one sequence of your loop; if those few tenths of a degree of difference will
make or break your setup you should just go ahead and increase your radiator surface.
			No not really lol. Water is traveling so fast that heat differences are very small.
And ^this is why the temp differences are so small.
			ill probly go from the top rad to the componets to the botom rad ten into the res in theory that would be less work for the pump since alot would be flowing down instead of up
In a closed loop, there is no difference for the pump between flowing up and flowing down.
Think of it this way: You have two tubes, one going up and one going down, and they're
connected at the top and bottom, respectively. If you start pumping the fluid around in
that loop, the bottom end of the fluid which is in the downwards tube will press up against
the bottom part of the fluid which is in the upwards tube (yes, I'm aware this is a very
drastic simplification of fluid dynamics, but I think it gets the point across without being
completely unrelated to reality).
			ok well how would i go about the drain loop
For starters, as has been said, pick the lowest point of your loop and make an outlet
there. This can be as simple as a hose you just cut/disconnect (which can get a bit messy),
or something more sophisticated like a T piece with either a quick disconnect or a ball
valve. Google around a bit, I'm sure you'll find some helpful examples with pictures for
inspiration.
Secondly, you need to make sure that there are no dead spots in your loop. By that I mean
something like this:
		Code:
		LOOP COMING FROM TOP
|    _____
[color=#ff0000]|    |[/color]   |
[color=#ff0000]|____|[/color]   |_____ LOOP CONTINUES
         x DRAIN PORT
In a setup like that, the red part of the loop will not get drained properly (I hope the schematic
is understandable). Note that it can be a bit tricky to get a loop to drain completely, especially
the radiators, so there might still be some fluid left even if you have the drainage system
set up well. Also, it might not always be possible to have no dead spots, depending on
your setup.
