pepsibackfoolyo
Ok, so I'm getting a new Graphics Card and I need a better power supply and I don't know what kind of power supply do I need or if I can even run everything that I'm putting in my computer ok so this is the card I'm getting.
EVGA GeForce GTX 750Ti Superclock w/G-SYNC Support 2GB GDDR5 128bit, Dual-Link DVI-I, HDMI, DP 1.2 Graphics Card (02G-P4-3753-KR)
Base Clock: 1176 MHz
Boost Clock: 1255 MHz
Memory Clock: 5400 MHz Effective
CUDA Cores: 640
2048MB GDDR5 128bit Memory
300 watt or greater power supply required
Microsoft DirectX 12 API (feature level 11_0) Support
And this is the POWER SUPPLY EVGA 500W 80PLUS Certified ATX12V/EPS12V Power Supply 100-W1-0500-KR.
This is my power supply I'm using now
+12v / 14a. _12v / 0.8a
+5v / 25a. +5vsb / 2A
+3.3v / 18A.
65 MAX +5v & +12V 218 MAX .
This is my overview of my system.
AMD phenom(th) 11 X4 960t processor 3.00 GHz
4.00 GB
64 bit.
I hope I give everything I need to get this question answered, thanks..
CUDA Cores: 640
+3.3v / 18A.
4.00 GB
64 bit.
