Yes, i know the name is boring, but so am i......
Anyways, here are the planned specs;
Silverstone LC14 with vfd and remote (have)
Abit AB9 (ordered)
Core 2 Duo 6300 (have)
Geil ddr2 2gb (have)
4 x 400GB HDDs (have)
FSP Epsilon 700w PSU (HAVE thanks to oc3d)
x1600pro (have)
Dvd Writer (have)
Nebula Freeview Tuner (have, will upgrade in the future to a dual tuner)
Inside Case A
Inside Case B
C2D E6300 & 2x1GB Geil 800
4x 400GB HDD's, X1600 pro hdmi and Dvd Writer
X1600 Pro HDMI
Fitted HDD's and Optical Drive
Update!
After having sooooo many problems, finally more or less finished! Had a hard drive fail on me so im down to 3x 400GB instead. I'll post pics of the finished internals when i get round to opening it up again. That should be when i look at the cooling situation. Anyhoo!
As you may of seen in another thread, this is my new set up!
Really liking Windows Media Centre
This is the "My Movies" add on which allows you rip all of your dvds onto your hard drive, it grabs all the info for you.
I know frag will like this one!
Have another addon called "webguide", it allows you to schedual recordings or even watch them from over the internet. Here's me logging in from my phone!
I just set up supernatural to record whilst at the shops, really is a great bit of software!
I really happy this is finally up and running after a long list of problems. I'll post more pics on here when i put some quiter fans and hs in.
Abit AB9 (ordered)
x1600pro (have)
Dvd Writer (have)
Inside Case A
Inside Case B
X1600 Pro HDMI
Update!
