This is the original thread about the build:
https://forum.overclock3d.net/showthread.php?t=81728
It's been mostly great for the last 3 years, but the storage is maxed out. I have some music and movies, but most of the storage is taken up by my Wife's photography business. I did have to switch the board as the ASRock board was having issues. Every ASRock board I've had eventually starts hard locking on me. BIOS updates will fix it for a bit, but eventually it happens again.
Old specs:
Ryzen 3 1300x
8GB Corsair Vengeance LPX 2400
Corsair CX450 power supply
Gigabyte B450M DS3H
4x WD Red 3TB Drives (Storage RAID 6)
2x 1TB drives (OS RAID 1)
Some no-frills ATI video card
Adaptec 6405 RAID Controller
Icydock 4 bay cage with backplane
CM HAF case
Windows Server 2016
New:
I'm reusing the CPU, RAM, Motherboard, 4x3TB drives, video card, Icydock, and HAF case.
Adding:
4x8TB IronWolf NAS drives
Corsair TX650 power supply
LSI 9207-8i HBA
Intel 80GB SSD
FreeNAS 11.3
Some old pics:
The CX450 power supply only has 6 sata connectors. I had access to a TX650 which has 8 connectors so swapped that out.
I bought this intel 80GB SSD when it released. Paid $300 for it. Should be fine for freenas...or so I thought.
LSI 9207-8i HBA:
Seagate Ironwolf 8TB NAS drive x4:
Mostly finished build pics:
I did run into an issue with the Intel SSD. For some reason it's not detected at all. Not sure if it's dead or if it's something with the onboard SATA controller. Instead, I used a ~500GB NVMe drive I had in storage. Just a little overkill for FreeNAS, but better than being wasted in a drawer I guess.
FreeNAS is installed and working. I had to disable Cool 'n Quiet and C states to get some stability in FreeNAS. Older Ryzen chips have issues with it for some reason. The newer 2000 and 3000 series seem to be fine according to their forums.
Old specs:
Ryzen 3 1300x
Gigabyte B450M DS3H
CM HAF case
Windows Server 2016
New:
Adding:
LSI 9207-8i HBA
Intel 80GB SSD
FreeNAS 11.3
Some old pics:
LSI 9207-8i HBA:
