Hello Guys,
I'm still new @ this forums and Happy to get into So I Own already a system With Specifications :
ASUS P9x79 Deluxe
Dominator GT 1.5V 16GB Quad Channel DDR3 Memory (CMT16GX3M4X2133C9)
I7 3930k
Corsair Power Supply Pro S. HX1050
Corsair H100 Cooler With Push&Pull 4 FANS (2 Stock FANS & 2 Noctua NF-F12)
and Until Now Still looking By Google but can't get Success as didn't find the same System with anyone So I hope to get OC from here
Note : That one was my Last and also not stable
So I tried the auto tuning and that get me to 4.9MHZ without stable and tried the Auto with 4.6MHZ without stable Finally used the manual with 4.7MHZ without sable with those details:
Ai Overclock Tuner – Manual
BCLK Frequency – 100
CPU Clock Gen Filter – Enabled
Memory Frequency – made this to the stock frequency 2133
EPU Power Saving Mode – Disabled
OC Tuner – Not touched
DRAM Timing Control – made this as the timings listed on ram 9-11-10-27
DIGI+ Power Control
- CPU Load-Line Calibration – made to High
CPU Performance Settings
- CPU Ratio – made this to 47
- Enhanced Intel SpeedStep Technology –made this to Disabled
CPU Vcore Voltage – made this to 1.3, Started at 1.3v and seen it's not stable then raised it up by 0.025 each time until 1.325
CPU VCCSA – this at default
DRAM Voltage (CHA, CHB) – made to be the same voltage of my ram 1.5v
DRAM Voltage (CHC, CHD) – made to be the same voltage of my ram 1.5v
CPU PLL Voltage – at stock or 1.8v, anyway already the same
VTTCPU Voltage – made this to 1.3, Started at 1.3v and seen it's not stable then raised it up by 0.025 each time until 1.325 (changed with the CPU Vcore Voltage each time) to the same Volt)
ASUS P9x79 Deluxe
I7 3930k
DIGI+ Power Control
