ScottytooHotty
Member
I have watched some video's and done some reading on overclocking and decided to give it a crack, I have 8700k(not delided) on an Asus Strix z370-h gaming motherboard with Corsair vengeance 3000mhz ram and an NZXT Kraken 360mm cooler. Full spec below.
I am able to get a stable OC at 4.7ghz 1.3 volts and good temps at max 74c but as soon as I try going over that I start getting issues at 4.8ghz while running prime worker 10 has a fatal error every time and I am not sure what is causing it?
Bios settings that I have changed:
Ai overclock tuner = XMP
Asus multicore enhancement = disabled
CPU core ratio = Sync all cores
core ratio limit = 49 on all cores
cpu load line calib = level 6
intel speedstep = disabled
Long duration package power limit = 4096
Short duration package power limit = 4096
Cpu core/cache voltage = manual mode
-CPU core voltage override 1.340
I have images of the whole bios and the error messages that I am getting but can't upload them for some reason.
