Maby you've changed NVIDIA control pannel settings or summin.
I think you should re-install drivers and use the sweep option in custom install and if you don't use 3D don't install that. I've re-installed driver when there was a problem and it didn't fix it and i fixed it by deleting the driver. Because re-installing without deleting doesn't delete profiles, setting stuff and they are glitchy and after enabling SLI re-boot
I LOVE U MEHNN ... no homo ¬¬ but i works, so it was a simple as deleting the drivers then reinstalling it again![]()
im going to leave this thread up for people who might be in the same situation
thankksss![]()
My flickering was about four times faster than that and affected any 2d text box etc on screen, but not the actual 3d game itself. RMA time, sir
thankksss![]()
tried it but no luck![]()
I get 2d windows like internet pager flikering after enabling SLI so I re-boot and it works properly with SLI
Thanks ComputerGenius good luck
i hate to say this but ITS BACKKKKKK T.T it reinstalled the drvers again but no luck ¬¬ sigh* back to square one![]()
Exactly what i'm talking about! It goes away and clears up then soon as you think it's stopped BAM problems again!
i was reading about online and some people have the same problem and it was the sli cables problem, so im going to have to buy one off ebay or something like that ¬¬
240 rad isn’t enough for a dual gpu setup, get at least a 360 rad.
