I just recently put my computer back together after some extensive clean up and for some odd reason the Motherboard does not want to power up.
The main Power (blue) LED switch powers on for a little while (a few seconds at best) but then it dies down and nothing happens...none of the peripheral components turn on. A red LED also shines near the bottom of the board (near the IO ports) but fades away in sync with the main Power switch (as mentioned above).
I have double checked all my components for any wiring faults or shorts but everything was as it had been before. The board is safely mounted into the case with ample room away from any possible interference. Also did a quick hot plug on my AX850 (using a paper clip) and it seems to be running fine...
HOWEVER I did hear a Loud POP sound the other day when I was doing initial checks on my PSU (I was testing my fans)... that could be a possible suspect
I understand Tom has had some experience with this board so any help would be much appreciated.
Things I have already tried:
Used the extra EPS & PCIE cables provided with the PSU to rule out possible cable malfunction.
Reset CMOS battery
Held down CMOS button when powered down
Used high pressure compressed air!!!!
Reset CMOS battery
