spannah_munkey
On the advise of james(riley94) I have reposted the components list of a rig I hope to build in a few weeks time....
Case: CM Storm Stryker
Mobo: Asus P9X79 Pro
CPU: Intel 3930K
PSU: Corsair AX850 with Corsair's replacement sleeved cables
GPU: EVGA GTX680 (not decided if going SLi yet)
RAM: Corsair Dominator Platinum 1833Mhz 16GB (might go 32G)
Fans: Bitfenix Spectre Pro - All White
Watercooling:
CPU Block: Watercool HK Rev.3 special edition Black and Chrome
GPU Block: Watercool HK GPU-X³ "Hole Edition" Ni Bl and Backplate
Rad (roof): EK CoolStream XTC 280
Rad (floor): EK CoolStream XT 240
Fittings: Bitpower 1/2" Barbs - Shiny Silver
Tubing: Tygon R3603 7/16" - Clear
Pump: Laing D5 Vario with Bitspower Mod Kit
It's just an idea at the moment, theme is white, blue and shiny silver to match colour scheme on mobo, not sure what colour coolant to go with though, can't decide whether to go "OC3D" blue or white.
So wadda you think so far peeps? Is it a
or a
CPU: Intel 3930K
Watercooling:
