i'm looking into some sheet-metal grafting, possibly. meaning, id like to use the
side panels off of the Corsair 400/500r and use them on my Cooler Master 690.
i know the dimensions are probably outta-whack and if so, i can fuze one from
the other.
question is, this is thin metal and my welding skills are not that keen so
should i get them welded or bond them together with an epoxy?
usually the epoxies leave trapped air bubbles to make it a finishing nightmare.
the exterior paint will be a satin to low-gloss white, nothing mirror-like in
finishing.
the back-side finishing will be coverage and noise damping material.
maybe a window or not,hadn't gotten to that vision, yet.
thank in advance for comments or suggestions.
airdeano
the other.
finishing.
airdeano
