Ah, in that case, it makes more sense. Still a bit pricey, if he is not OCing
I've only ever owned 1 air cooler and that was the hyper 212 evo, not too sure on them. I'll have a look on the Aria website. That's my local parts shop.
I've had alot of success with the hyper 212 evo.
IF you can't get one, get a artic freezer 7 pro. It can also support mild OCs so its more then capable.
RM 550 should be a good un' . Knowing S***y system builders I bet it has an i7. I reckon an rm 550 and a cheap cooler, like the hyper 212 evo should mostly save that rig.
In process now, has a 4670(non K), before I opened it and knew what was inside I recommended an SSD, he said he doesn't even know what an SSD is. Turns out to have a 250GB Samsung 840.
Actually the rest of the rig seems to not be that terrible of a choice.
I had to stand by and watch someone get conned into a £30 hdmi cable by a Maplin employee on Sunday.
I almost cried![]()
He genuinely bullshitted the guy into buying a more expensive cable because the 'quality would be better'
IT'S DIGITAL YOU ******** PIECE OF SCUM STOP CONNING PEOPLE.
So glad I understand tech enough to not be conned by these jokers. It was disgusting.
Oh dear! I shot down a Techguy in PCWorld while buying a external HDD, with one simple comment, I gave him the look and said "Don't even bother".. Sad sales techniques employed by these highway robbers is rediculous.
It makes me furious, absolutely furious. 100% daylight robbery and false advertising. The guy even said "So with the cheaper cable, I'll lose quality" and the sales guy said yes. 100% bullshit.
I've had an arguement with a PCWorld employee in the past regarding why iMacs Macbook Pro's get/are generally hot...
They're effectively heatsinks, the whole chassis is designed this way, he denied it saying they don't get hot... I almost punched him. It's like have you PUT YOUR HAND ON ONE OF THOSE THINGS. it's HOT you moron!
You should go in there and act dumb and ask for PC advice.
Or Ask something simple like "I have 16GB of ram but it only shows 4GB"
Urgh.I had to stand by and watch someone get conned into a £30 hdmi cable by a Maplin employee on Sunday.
I almost cried![]()
Or change the administration privileges on the demo models then set Marque screen savers with your own message and change the password.![]()
