Fan control by watertemp
Korreborg
Member
Hi
I'm in the start of planning a custom watercooling loop.
The current plan.
Corsair 250D
EKWB
SE 240
CE 140
= 3 fans and a DDC pump. (EK-SBAY)
EDIT: I want to be able to control the fans according to water temperature.
Aquacomputer Aquaero seems to be the way to go, but 100€ to control 3 fans?
Any better options, or is Aquaero just THAT good :D (I want the 6 LT due to heat output)
Corsair Commander mini = No way, just as expensive, and i have had problems with the software :)
Aquaaero is THAT good. but with their new policy i find BS, you will need to pay a license fee to continue using their software.
That being said, its not worth it for just 3fans unless you wanted to use it for your pumps too. But why control fans based on watertemp? water fluctuations will be slow and very small in comparison to fans controlled in proportion to hardware temps like CPU, GPU, mobo etc.
As i understand it, you can keep using it. You just cant update to a newer version of the software, unless you pay for it. Or am i wrong?
Because then the fanspeed will also only rise slowly. And all 3 fans will spinup/work together.
So in a game with 99% GPU and 40% CPU, all fans can work together. Instead of 2 not spinning up.
The goal is to be as quiet as possible :)
You can make your fans work together and rise slowly even if using your CPU temp on your basic mobo software. You just need to adjust the fan graph to not be so responsive on miniscule temp changes.
At the end of the day, it is your money to spend as you will. I use the Aquaaero XT6 and I love it, I just think its wasted money if only used for 3 fans. Of course you can expand at a later time. But depending on your fans being pwm or not, there are probably cheaper alternative like Lamptron CW611 if fans are 3pin.
But thats not fun :D
I have 2 Corsair ML120 and a ML140, so PWN. I will probably be getting the Aquaaero 6LT
Then there is room for upgrading :cool:
What motherboard do you have? My Asus Z97 Ranger had a "T-Probe" which I could connect a thermal sensor to and install it the loop. The Fans could then be set in the bios to react to the t probe temp rather than CPU temp, a cheaper solution if your board has the connector
Only relatively "new" boards have that option. I know my Crosshair VI does, but I haven't made use of it yet. Nice sounding feature on paper, but if they don't make it easy in the software or BIOS, it's a moot point. I'm going to try to make use of it just cause it's there, and I can, same reason you want it. :D You should have loads of fun with an Aquero!
