Dawelio
Active member
Hello everyone,
So I'm waiting on the release of the upcoming Lian Li O11D Mini case, which unfortunately has been delayed around 6 months, but seems to be getting closer and closer, hopefully mid November.
As with any build, planning is a huge part of it. Hence this thread.
I'm a bit unsure on what size fans I should go for, dual 120's or dual 140's on the side of the chassi. The side, meaning the fans to the right (on the AIO) of the motherboard in the picture below.
I will otherwise, fully utilize all fan spots in the case; one 120 in the back, triple 120's in the bottom, triple 120's in the top (AIO) and then there's the dual fans on the side. Which I am having a hard time deciding on. I'm not even sure if it even makes a huge difference between 120 and 140? Especially considering the colossal amount of airflow that the case will have anyway. At this point, it's just the aestethics with it, which is something I'm rather picky about.
In the end, it will be up to me to decide whatever I go for, although I've wanted to ask you guys for a while now what everyone's opinions on these are, what you would choose yourselfs in my position?...
The fans I've thought about are all Corsair ML120's and ML140's (if choosing for 140's on the side). They will be a nightmare to cable management, but this is something I'm willing to do, especially since this is pretty much a one time thing that you do. So not a huge thing overall.
If all 120's, then I might consider the Lian Li Uni Fans or similar. Due to their ease of cable management. Although I don't want the cable management to be deciding factor, since this isn't something that you will see anyway (I'm picky on clean and slick cable management in my build). So it's mostly down to size(s) and aestethics.
What do you guys think and what are your thoughts on this?:
Best regards,
Dawelio
Best regards,
Dawelio
