The leaky Ultitube was fixed with a new washer / gasket - used the replacement / new Leakshield to test by filling reservoir to halfway, ports blanked off and seeing if it would generate some negative pressure - saw something like 471 mbar so all good
So with a big pile of bits about the place I decided to finally put it all together like I'd planned to months ago..
Oops - I'm doing it again by
Robbie Corrigan, on Flickr
Lian-Li 011D - Evo in Grey and in Reverse mode config
2 x Aquacomputer Radical 360/2 (Stainless Steel / Copper)
6 x Noctua 120mm Industrial 3000 PWM
Pump, Res and Vacuum by AquaComputer (D5 Next, Ultitube Pro 150 & Leakshield)
CPU Block by AquaComputer (cuplex kryos NEXT VARIO with VISION)
GPU Block by TechN (RX6800 Series Full Cover)
Intricate by
Right, these f things! These are the most excruciatingly annoying things I have ever come across in IT. To mount the radiators, fans, pump, reservoir, etc you're going to have to plan in advance to be able to do everything on a horizontal level and even then the little f's will shift and move about.
The Rads themselves are nice quality if a bit fragile fin wise, really soft. You can ping out of alignment with a fingernail no problem.
Copper Duo by
So in reverse mode, one by Rad in front, vertical with 3 fans pulling air in and pushing though. Pump, Res and Leakshield unit using the Aquacomputer 120 pump mount. 2nd rad is on the bottom with 3 fans pulling air in from floor. Pump - Vertical 360 - TechN (GPU) - Cuplex (CPU) - Bottom Rad to Reservoir
I still have the Aquaero in place, primarily to drive the fans but the D5 Next also has a 25W fan header so I might decommission that and tidy up some cable runs.
The TechN just works, very much function over form
Screenshot 2022-07-01 014420 by
RGB stuff
Bling bling by
All done until Zen 4 & RDNA3 arrives
