The_Governour
Ok, I would like to share some experience with these expandable AIO´s that are out there:
Raijintek Triton AIO:
Fractal Design AIO series:
Alphacool Eisberg AIO:
Raijintek Triton - I bought one of these as it has one of the more pleasing pumps and most L/per hour. This is expandable yes BUT....... and a big BUT.... you can only change the tubing as the barbs WONT COME OUT. You can NOT use the 1/4 barbs with this AIO. I broke one trying as I had not realized that the barbs would not come out.... Now it leaks and I can throw it away - was not even mounted once - still has the platsic cover on the pump!
Fractal Design S series - This is a nice AIO that is very clean and works well but has the intake and out take on the pump block are on the side - then yet again it will be very hard to use standard 1/4 barbs compression fittings like 1/2" - 13/19mm - so you would have to use the smaller ones that are standard on the S series. Also the pump can be noisy on full load.
Alphacool Eisberg - This has good enough spacing to fit a angle fitting and to use the 1/2" - 13/19mm compression fittings. On a side note then its important to get the low noise edition pump OR the New V2 Eisberg pump block that they have recently released.
All of this would be thought for a very small mini itx loop where space is a luxuary and just a pump block res like one of these 3 would come in handy.
