Haha good one, keep at it, you'll get used to it. Make sure you keep it from bunching up, keep it nice and slim other wise you wont get it in the terminal.
Quick question, would it be better if I had a pair of 30mm thick rads, 2 fans on each, double pass through or a single 60mm thick with just 2 fans. Am I right in think the double pass will be better for cooling, because, I've just derped if not.
Cool man, I've was planning on sitting two rads in the bottom, sitting side by side due to space constraints, but I've managed to nestle in a rad (s) laying flat/ lay face down if you catch my drift. So it looks like a thick 60mm, 240 wit 2 maybe push/pull if I can fit it in then?
personally i think u should make it blend into the case as much as possible (i mean chamfer the edges and paint it the same color as the case and use less robust screw things ) sorry my vocabulary for such things is very limited. but yea basically make it blend into the case and it'll look nice and sleek
I get you bro. I am definitely going to be painting it the same colour as the exterior. I think I'll see what the plastic caps look like when its done, I like them personally, but otherwise, its cap head screws.
