EVOLUTION by PEXON Cable management/ few pics of progress
That sounds a bit tacky to me mate, I'm going for sleek and clean. I think I'm going to get it cut on the gap between the two windows.
sorry, I wasn't very clear
i meant backlight the name where you drew it
could look really clean if done well
My new PSU arrived today, so I've got started on that. Obviously, I've got limited sleeve left, so I'm going to have to make do with sleeving a portion with SATA sleeve on the 12v ATX and PCI-E 6+2 and the rest individually sleeved.
One end...
T'uther end
Looking sexy man! How do you get the the sleeving to go all the way into the power connector? Everyone I've seen has always put heat shrink between the sleeving and power connector.
I posted a little video a few pages back on how I do it. I use a lighter in that video, but now I use the tip of a soldering iron as its cheaper (than using a load of cig lighters), and is quicker and more precise.
i have the 1000w version of that PSU and besides the fact that it doesnt have a switch it is bloody awesome... so quiet. the caps in the gpu cables look daft though
nice sleeving btw
Yea man Ibe been surfing around and you can cut off the caps. All they do is cut out any whining sound when your GPUa are under heavy load eg. Heavy OCing
I had a spare bit of ally, left over after cutting the window out, I started measuring up a blanking panel for the front, where the 5 1/4" drive pay covers normally sit.
I also wolloped a few holes in the floor, for the intake for the 240mm rads. Fingers crossed, I can get a pair of 140mm fans in the front too, to help get a bit more air into the case, as 2x 120's in the floor, exhausting hot air from the rads, won't be too beneficial.
I'm just not sure how to mount the rads, either on the floor or fans on the floor of the case. Like...
OR.......
As always, cheers for looking.
Ah, yea man! I'm not one of these people who add a few watercooling bits to a case and can be done with it, I'm not going to leave anything to chance, everythings gotta be looking good!
