dual heater core for waterchill kit?
iloveamd64
im thinking of buying this for this
the water cooling kit ive bought only comes with a 80mm rad so ne feed back would be helpful.... reps will be given for the most helpful :yumyum:
Well a lot of people here will tell you that Asetek kits aint so good. But to be honest if I was looking to step into watercooling I would consider them. Yes you do want a 120mm RAD for that kit as 80mm won't do shit!
Hope I helped! ;)
did you have a lok at the dual heater core? i thinking of buying that then schrounding it. and having the 80 rad aswell... still cant seen to find out wat fittings the water cooling kit has? i dnt know if they are 1/2 do you know? i only bought the kit as a starter then upgrade it when i got more money the first thing ill do is the rad then cpu/north bridge/vga blocks then a more powerful pump
If you're going to buy a kit, and dead set on it then the Asetek or Swiftech kits are the only ones worth spending your money on because they're the only ones that will allow you any future upgradability and performance gains.
Heatercores are the way to go if you can build/find a shroud for them, the 80mm rads don't do SHIT... I would just throw it away when it comes in or sell it for $10 on ebay because it's completely useless.
If you have the money, or the inginuity build a kit from the ground up!
fragtek can you send me a guild to srchoding? im going to buy the dual heater core for my water chill(alread bought it) :( i was on overclock.net and you were a big help to me there but wont go on there coz they banned xms cheers mate
haha, thx :)
unfortunately I don't have a shrouding guide.... that might be something to ask the magical PV to whip up for us. He's the guide king and I just don't have time right now to research it and write a guide on it.
