DFI LANPARTY UT nF4 SLI-DR
clone38
Is this motherboard worth the extra money over the SLI-D version,i.e is it a more stable board as i will be setting my phase cooling up soon.
Thx :)
maverik-sg1 said:
no more stable my friend - just has RAID capabiltiy.
AFAIK thats the only difference.
Mav
Both have RAID iirc, the R means it has an extra sillicon chip giving it 4 more sata ports tho...
I dont use raid and only have 2 hds fitted,lools like i`ll get the SLI-D.
Just wanted to make sure that there was no difference in the boards when phase cooling is used.
Thx :)
Thx :)
Ultra-d can be modded to Sli-d easy :p
I may have the chance of getting a secondhand SLI-DR is there any revisions of this board i should stay away from.
Thx.
AFAIK no there are plenty of bios's to flash too depending on what type of ram you are using.You will find them on dfi street.
