Dell Facepalm
hmmblah
Administrator
Staff member
I have a few Dell Optiplex 740 systems here at work with 2GHz AMD X2 CPUs. I need a little more power in them so I contacted my Dell rep to see what the max CPU supported in this systems is.
She replied with this, "I cannot send anything out on an OptiPlex 740 due to a non-disclosure agreement."
...really...
So I contacted Dell Government support online chat. I was told the X2 is the max CPU supported in the 740...then I found this link and pointed out to him that a quad core phenom is supported and I'm just looking for specific models to ensure they work.
http://www.dell.com/downloads/global/products/optix/en/740_customer_brochure.pdf
He tells me to call tech support.
So, I call tech support, get transferred a few times and ask my question. I wait on hold for 5 mins and the tech gets back on the line. She says the following in broken English. "Sir, I am happy to tell you can upgrade system with faster CPU, but must be i3 or i5 CPU."
......... ... ..... .... .... <-----That's extended silence from me.
Tech: Sir, are you still there?
Me: Yes <sigh>
Tech: Have I solved your issues, sir?
Me: <sigh>
Tech: Sir?
Me: Yes
Tech: Sir, thank you for calling Dell, would you like me to close this case?
Me: <sigh>
Tech: Sir?
Me: Yes, <click>
/facepalm
Still don't know what CPU I can upgrade these systems with...
i don't know if this will help you but the tech specs for that dell is listed here:
http://web.amd.com/e...40techspecs.pdf
looks like the X2's are the fastest cpu's they'll take, but you can upgrade to 2.6GHz from your 2GHz
edit: i looked at the link you posted.... i don't know why that information is different then the one i linked.... sorry i can't be of more help :S
So i am curious did you try to put a i5 into a AMD mobo?
It looks like the Phenom 9750 and 9850 will work....unfortunately trying to find them is proving difficult.
