Custom build under $1000?!
If you're planning to OC your system, I'd definitely go for the NZXT Havik 140. It gives you more headroom for cooling potential and it doesn't have many restrictions with RAM clearance.
From the selections of the AU online etailer, I've found a couple of the following that may interest you.
Memory:
Kingston 8G(2x4G) DDR3 1600MHz CL9 HyperX
G Skill 8G(2x4G)DDR3 1600Mhz PC3-12800 CL8(F3-12800CL8D-8GB
Video Card:
MSI GTX570 Twin Frozr III/OC
Gigabyte GTX560 GOC 1G DDR5 PCI-E2.0 DualLink DVI Mini HDMI (Can be SLI)
thanks all for your help
i7 2600K/i5 2500K
Asus P8Z68-V PRO-GEN3
Kingston 120G HyperX SSD SATA 3
Corsair HX-1050 1050W/CoolerMaster 1000W Silent Pro Gold Modular/OCZ Z-Series 1000W Modular PSU (cross between these 3)
NZXT Havik 140 Cooler (or might just use my existing Coolermaster TX-3)
Memory preferably under $100
http://umart.com.au/newindex2.phtml?bid=2
Graphic card under $400, can be single or crossfire or sli
nooby
Memory http://www.pccasegear.com/index.php?main_page=product_info&cPath=186_218_1125&products_id=17933
Graphics http://www.pccasegear.com/index.php?main_page=product_info&cPath=193_1177&products_id=17812
crossfire 6870 or single 570? ends up being a little cheaper for crossfire that's all
ocz/coolermaster/corsair powersupply? corsair is just a bit too costly.
thanks,
nooby
I adjusted it to suite the budget abit
i5 2500k/i7 2600k
Gigabyte GA-Z68XP-UD3R
WD Black 500G SATA3 (SSD waiting for price drop)
video card shortlisted:
Asus GTX 570 PCI-E 2.0 1280MB DDR5 2x Dual-Link DVI 1x mini HDMI Fan
eVGA GTX570HD SC1280Mb PCI Expresss
or maybe crossfire or sli 2 cheaper card
i wouldn't bother sli'ing 2 cheaper cards its not really worth it price/perforance wise (man with very recent experience speaking)
I'd also go with the twin frozer card, I have 2 560ti's (buying a second was not worth the money i paid) 1 is a twin frozer and the other is asus direct cu. the twin frozer is clocked 50mhz faster on the core and is about 9-10c cooler. and looks better imo.
You could also consider a scythe mugen cooler it would help keep the price down. I have one of these and it is fairly quiet and keeps my CPU at a max of 46c over clocked to 4ghz (but it is an amd processor).
PSU= http://www.scan.co.uk/products/1000...-plus-sli-crossfire-eps-12v-quiet-fan-atx-v23
Its by antec so should be of decent build, and is 115amps on quad rails. is a bit of a beast and not exactly a good looking one at that but still will help you keep the price down
