Corona CPU Benchmark Released
Corona 1.3 Benchmark Finished
BTR Scene 16 passes
Intel(R) Core(TM) i7-5820K CPU @ 3.30GHz
Time: 0:02:42, Rays/sec: 2,999,290
Running @ 4.4, 16gb corsair @2666, X99 Sabertooth
Ran it on one of our servers here at work.
8core/16thread using E5620x2 Xeon 2.4 Ghz Processors
48 Gigs Ram
Wonder what my gaming machine will do at home later as it took this server to 100% utilization
I think this is only the second i5
BTR Scene 16 passes
Intel(R) Core(TM) i5-4690K CPU @ 4.50GHz
Time: 0:05:28, Rays/sec: 1,481,810
More detail on system:
i5-4690k @ 4.5GhZ
16gb 2133MHz ram
MSI gaming 5
i5 4670k @4.5Ghz
BTR Scene 16 passes
Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz (4.5GHz)
Time: 0:05:47, Rays/sec: 1,402,010
Just my Lenovo X1 from 2014
I7 4650U with max 3.3ghz
16GB Ram @ 1333mhz I think.
2 cores 4 threads btw.
BTR Scene 16 passes
Intel(R) Core(TM) i7-4650U CPU @ 3.30GHz
Real CPU Frequency [GHz]: 3
Render Time: 0:07:58, Rays/sec: 1,017,322
And as a sharp Contrast to my own rig, here's the results from my partner's PC. (She doesn't care about specs like I do.)
BTR Scene 16 passes
AMD FX(tm)-4300 Quad-Core Processor
Real CPU Frequency [GHz]: 3.9
Render Time: 0:12:43, Rays/sec: 636,587
An i5-4670K @ 3.40GHz, 4 cores, 4 threads.
8GB RAM DDR3 @ 667MHz
BTR Scene 16 passes
Real CPU Frequency [GHz]: Undetected
Render Time 0:08:12, Rays/sec: 986,492
The picture
Some very interesting results so far guys. very interesting.
For example look how close TTLs Sandy Bridge i7 3970K and my Skylake i7 6700K is, not bad work for Skylake given the fact that the Sandy bridge CPU has 2 more cores.
We can also see here that a lot of the i7 4790K CPUs deliver very similar performance despite being in different systems.
BTR Scene 16 passes
Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
Time: 0:04:00, Rays/sec: 2,024,530
It is OC to 4.2 at 1.25 Tried to get a picture under load, max 64C at 100% load. This is my gaming rig. Going to play with OC to see if I can get more
This bench is hinky, it always produces better scores the more you run it. Mark you should look at the Alpha4 Bench, it has better CPU recognition and memory usage.
With 1.3 my benches always run to 4:18 but at 4:16 there is a pause and a huge drop in Ray/Sec count from 2,010,000 to 1,890,000, add this to what the devs of the render say is a problem with the VFB not being refreshed as it should. They also claim on their forum that Ivy performs better than Skylake and Haswell and no one knows why..
So I'll leave this here, see what you think.
Corona Alpha4 Living Room Bench.
here is mine
BTR Scene 16 passes
Intel(R) Xeon(R) CPU E3-1231 v3 @ 3.40GHz
Real CPU Frequency [GHz]: 3.6
Render Time: 0:04:52, Rays/sec: 1,663,250
