Ok I have had a few people ask me how I insulate my mobo's to protect against condensation this is a very rough guide..
I always use the rear mount from the mach2 heater pad and all first off I use dialectic grease on the rear square where the backplate is going to go
DO NOT PUT DIALECTIC GREASE WHERE THE SEAL STRING IS GOING TO GO
I have no pics of my rear mount as I accitdentally erased them from my camera
Use one round of the seal string around the mounting plate if you need to modify the plate ie file in between where the bits on the mobo stick up then do so so you get nice even contact with your mobo and the seal string
Then I go around the outside of the plate with another round of seal string pushing it into any air gaps that may be left
Push your mounting screws through the holes in the plate and tighten them down
I then smeer dialectic in and around the socket on the mobo making sure I have a lot of coverage on all the components arounf where the evap will mount
From this diagram you can get a rough idea as to where I put the grease you can also see the neoprene gasket I have made to go around the socket retention mechanism
